I just had a new cambelt and water pump fitted. I arrived home and had a look ... it seems they did not replace the clips on my engine bay cover trims. Which specific clips should I order (assuming the garage has lost them, I will call them in the morning).
Thank you
That really is appalling service Trefor. Was it a Lexus garage?
Whichever it was, you should not have to replace them as the garage has not done its job properly.
Absolutely John
I will call them in the morning (collected car at 5:20, drove home, lifted bonnet, they close at 5:30) and I expect it sorting don't worry. But just in case I thought I'd check which the clips were, might be easier to just get some for a few quid.
They are a local garage, very good people and have looked after my cars for years. So I won't 'diss' them. Hopefully they will sort it promptly.
You may yet discover that the garage has a 'lost property box' in the workshop that contains miscellaneous components that appear without reason - - (or explanation)
All sorted, they fitted clips in 2 mins when I went back this morning, they are only in the village so not a major inconvenience.
