My lexus gs 250 speakers emit loud crackling sounds even when system is off. It seems to happen when going over uneven surfaces
Sounds like ground noises, probably made worse by stripped insulation on speaker wires which are rubbing against charged metal as the car moves.
I think you'd need to check the speaker wiring.
