Hi folks.
My aircon pump has started to make a loud noise when it's running. I assume this is one of the bearings that is about die.
I was thinking of replacing the pump.
However while watching a car refurb program, I saw that the pumps can be refurbished. (New seals and bearings.)
My question is, does anyone know where a kit can be found? The interner was fruitless.
Hi Jon
I don't know about refurbing those but I would recommend fixing it as soon as possible. If the impeller comes apart and spreads debris throughout the system it can be very hard to fix - you have to replace several components in order to make sure the system doesn't remain contaminated. If there's debris left in the system after a repair it will take out a new pump in short order.
Some good information on AC repair here: http://www.agcoauto.com/content/news/p2_articleid/259  (this is part 4 of a 4-part series).
Mark
Yes m4rkw. I'm aware of the problems leaving it too long can have.
Hence I want to tackle it now.
I coould just send it for refurb but all the do is replace it. If a kit was available it would be easy to do.
