RX450 Infotainment System Software Update
Hi all,
I'm new to the forum, but not to owning a Lexus (CT200) and now a 2010 RX450.
Does anyone know if it's possible (and if so, how) to update the software in the 450 to the new look of the 2015 (pre-facelift) model?
image.thumb.png.afa811f7e5260faff2599c60e55c24fc.pngimage.thumb.png.5e3849c3663be764b4d38f218c073e1e.png
It's not possible unfortunately. In 2012 a new navigation ECU was used so it isn't just a case of upgrading the software.
Thanks Colin,
Soo, with that in mind, will the newer Navigation ECU work in the 2010 model? I can understand it may need some tweaking.
Thanks Colin,
Anything is possible, but I don't know if you need other components such as headunit or wiring alterations. Unless you can find a used navigation ECU and HDD it also wouldn't be financially viable.
On 7/6/2021 at 9:57 AM, ColinBarber said:
It's not useful for anyone in the UK, or Europe, as Lexus in the US use different infotainment systems that aren't compatible.
Not necessarily, I made it on my RX and it worked.
