hi guys and gals
got the engine light on whilst driving, diagnostics shower DTC P2047 Reductand injector circuit/open. i guess it is 5th injector or connections faulty. is it worth to change the injector or map it our with pdf and egr altogether? will i need to physically remove the pdf filter from the exhaust? anybody here done this? my car is 2011 is200 2.2 diesel
thanks a lot
I would change the injector and fix the engine correctly.
You alternative proposal would leave the car illegal for road use (with knock on insurance issues) and an MoT failure.
thanks for reply Nemesisuk, do you reckon it is injector, nor the power supply?
thanks
I suppose easier to check the electrics first? One could test with a multimeter.
Was the diagnostic test done using Techstream?
not techstream, just an universal obd reader. ill check the connections as soon as the raining stops 😁
