Ive been trying to find out how to get access to sound outputs to connect Amp and sub. I have looked and searched the web for days. I could just run the wires from behind the stereo but i want to tap off the amp if there is one to make my life easier. Also would like to know what colour wires to look for to tap off and create rca inputs for an amp.
What spec sound do you have in the RC? Does it have Mark Levinson?
Its not the Mark Levinson system. However I have installed the android 9 screen. which works a dream.
have you tried looking in the rear quarters of the car under the boot floor
i know the GS's amp is located under the boot floor in the drivers side rear quarter
yes i had a look and no its not there. the other side has the Battery in it.
do you have the basic audio system if you do i think the amp is integrated into the head unit
19 hours ago, Birdman2021 said:
yes i had a look and no its not there. the other side has the battery in it.
If it's not there then you have the Fujitsu-Ten 6 speaker audio system with integrated amp. Only the 10 speaker Pioneer and 17 speaker Pioneer/ML systems have an external amp.
Thanks.. well its going to be off with the rear quarters to access the speakers to tap off. I might do a little tutorial on this.
