2004 RX300 replacement pipe for auto box oil cooler.
Has anyone had to replace the above which is a U shaped combination pipe attached to the centre of the front X member as mine has perforated with corrosion so leaking auto fluid.
Thanks a lot for any info.
Thanks herbie, I did wonder if I might have to make one.
Thanks Steve, I think it’s the one in the bottom left hand corner which has 2 brackets attached and in the general shape of a U but the picture doesn’t show it fully.
I had the same problem but thought the cost of the pipe was a bit excessive, so I bypassed it and fitted hoses direct from the transmission to the oil cooler.
A bit tight as there's very little space around the connections. Probably why Lexus had the steel pipes on the crossmember, for easy assembly at the factory.
On 6/15/2021 at 2:43 PM, Lex Loofa said:
Have replaced the pipe, it cost £97 but grateful it was still available for a 17 year old car.
Thanks for all the help, Paul.
No problem, glad to help.
Lexus UK prices then......full retail + 40% + VAT 😀
