Is there a way to set a list of favourite destinations in the sat nav that can be retrieved so that a destination can be selected from the list?
Yes, I have read the manual. I have re read the manual.
In my 2010 GS I am offered the choice of setting a new destination or of choosing one from a list of destinations I have set previously.
Have a couple of points for reading and rereading your manual ikeja.🤞
Thank you Roy
I must be a retard as I cannot see how to set a list of destinations.
Am I the only one who has this difficulty?
Guess I need to sit in the corner of the classroom
Thank you Roy
No problem Barry. My system is from 2010 but when you go to input a new destination is there anything on the screen which mentions previous destinations ?
Thanks Roy and James.
Will have another go at this
Eureka, I don't know how I did it but success at last.
Thanks to Roy and James for your constructive help:)
Go to say nav screen. Select Menu. Scroll to Memory and select. Then edit if you want to edit and existing memory point. Or Register if you want to create a memory point. When creating a memory point it gives you a number of options- recent destinations, current location or address so that you can enter an address.
Thanks Paul, just picked this up. Problem is now resolved:)
On 6/11/2021 at 11:20 AM, ikeja said:
Thank you Roy
You are not the only one.  One moment I think I have mastered the Navigation. The next time I go to use it,
nothing does what I want it to.  I usually rely on my Garmin sat-nav which is far easier to use and always
up to date.
Was it worth it?
I ask because I agree with Alan’s post above.  My Garmin is far superior to the Lexus sat/nav that I have.  In fact I’m not even sure the Lexus one can now even be updated.  At best I believe it was biennial and updating cost about the same as a complete and superior Garmin system which came with a lifetime of four free annual updates!
It’s also very easy to turn off while driving- something I never managed to master with the Lexus system.
In short, yes. Worth it to me as I don't have a smart phone, actually prefer planning a journey by map than relying on sat nov, but when driving round an unfamiliar city sat nav is very helpful.
