Does the Lexus RX300 SE-L not come with front and back sensors?
That's very strange as top spec thought it would have?
Anyone knows?
No, a reversing camera but no sensors as standard as far as I know...
It does come with air suspension which can be problematic as it gets older.
Still love mine though!
@PCM
What does air suspension mean?
@PCM
Is it better or worse than regular car?
If you have the patience read the RX forum regarding RX 300. They are very good cars, I still have one but not for long! The air suspension can be a weakness when they get older. You also need to watch for corrosion on the rear sub-frame by extracting the spare wheel and checking underneath. If it has been well serviced and looked after they are cracking cars.
As an addition I have just had rear sensors fitted to my RX 300 for £180 including colour coded matching.
Go to the forums tab and click on RX300 and scroll looking for items on RX 300.
The link below mentions air-suspension problems - There are other threads, you should read as many as possible.
@Spacewagon52 @PCM @royoftherovers
I just found a great car on Auto Trader.
http://www.autotrader.co.uk/car-details/202105253050217?atmobcid=soc3
Download the app to find your perfect car.
https://play.google.com/store/apps/details?id=uk.co.autotrader.androidconsumersearch&referrer=utm_source%3DApp%20Share
this is the car I'm considering to buy, please share with me your thoughts
I have PM'd you.
https://www.check-mot.service.gov.uk/?_ga=2.156381432.2133495249.1621970292-399822042.1613999592
The some of the Citroën had poor quality air suspension, great while working. MB 50 year old air suspension cars are few, but never heard of problems with the suspension.
Looks good. Never thought a Lexus RX could be that cheap though. If you are not car expert, I would ask one to come with me looking at it.
I don't know if it is or not?
There have been lots of problems john with M.B. air suspension W220 S Class
Yes it is a well known issue when the cars get older that can be expensive. If you search through the threads you will see it mentioned quite a bit. The important thing is that to correct can be very expensive. Some members with air suspension have had no issues. It is an issue though.
