had to open the car with the manual key
no lights, no clicking, key wouldnt turn in the ignition, everything is totally dead!
how do i open the bonnet to check the Battery?
Get your head down in the driver's footwell and you should see a lever to pull, usually somewhere around the bottom of the trim. If it's not there, try the passenger side.
Thanks Herbie
of course thats it!!!
senile dementure kicking in
this happened to me once after parking in a supermarket, turns out the negative lead simply fell off the Battery. Hope it's also as innocent for you @deelcee
