Washing a car
On 5/16/2021 at 9:00 PM, Mr Vlad said:
I've actually used it a couple of times now in the past 3.5 years. However when I bought it I used it quite a bit until I got fed up getting it out, setting everything up and putting it away again.
Exactly my sentiments!
6 minutes ago, paulrnx said:
I have a Karcher. What attachments do I need so that I can apply snow foam using the lance?
Something like this, checking compatibility with the exact model of pressure washer you have.
https://www.amazon.co.uk/Lance-Karcher-Connector-500ml-Magifoam/dp/B00GU1YYA0/ref=sr_1_11?crid=3PML6ZDW6NXAN&dchild=1&keywords=snow+foam+lance&qid=1627813049&sprefix=Snow+%2Caps%2C158&sr=8-11
This one, from Halfords,  is cheaper and works well.
https://www.halfords.com/motoring/car-cleaning/pressure-washer-accessories/karcher-pressure-washer-foam-spray-nozzle-112221.html
11 minutes ago, Spacewagon52 said:
My Nikfisk pressure washer came with a cheap one like that. Trust me, you’d never go back once you’ve used a more professional type, they’re night and day in terms of application in my experience!
