Drivers Door Alignment
I have just had the drivers seat repaired and i have noticed that the drivers door swathe lines do not match up.
I am not sure if they would have to remove the door to remove the seat for repair but is it easy to realign the door by loosening off the hinge bolts or is it a more complicated operation
The door shouldn't have been touched.
Adjusting the doors is difficult. Not easy to get to the bolts and they are normally tight so you need the right tools, even then you only have tiny adjustment available unless you change the centring bolts for normal ones that give you more adjustment.
How is it out, has it dropped?
