continuously ventilated cold seats Lexus is220d
Hello, guys,
I recently bought a Lexus is220d and discovered that whatever I do, the front seats, even if they are turned off or on, blow continuous cold air. Do you have any idea what the problem would be? Or if someone can help me?
Thank you!
I have had the same issue on mine, however it was very intermittent. I turned on the cooling, to 3, and then waited a few seconds, then turned it off again. After that it stopped. I have had this issue once or twice
