1 hour ago, WilliamH said:
My Lexus IS300 SportCross - Navigator option - now uploaded for listing in the For Sale section on this site.
Thanks for commenting on this post earlier.
Kind regards
William
Nice advert William. Good luck with the sale which I`d have thought would be soon.
A well cared for and well maintained Lexus.
Is it a six pot 3 litre, or what ?
Thanks John. We'll see.
Yes, it's the 3 litre straight 6 - a beautiful engine.  Full spec below if you're interested!
William
3.0 litre engine
VVT-i – Variable Valve Timing – intelligent (electronically controlled)
ETCS-i – Electronic Throttle Control System – intelligent: advanced computerised engine management system
5-speed automatic Electronically Controlled Transmission (ECT-i) with intelligent computer control
AI shift system
Dual stainless steel exhaust system with catalytic converters
Cylinders/valves in line 6/24
Capacity 2997 cc
Compression ratio 10.5:1
Stroke/bore 86.0 x 86.0 mm
Maximum output 211 bhp (157 kW) @ 5800 rpm
Maximum torque 212 lb/ft (288 Nm) @ 3800 rpm
