Front passenger window
Hi, I have an 05 is200. When I clean the inside of my front windows I have noticed that something appears to be breaking down. Does anyone know if it is some sort of lacquer? Is there a tip to remove it? Whatever I try just seems to make it worse
Not exactly sure what you mean,have you got any pics?,could it  be that the previous owner tinted the front windows and the film is now beginning to flake and peel off 🤔
Got same problem on LS inside windows.   I discovered that I had used wipes designed for cleaning leather instead of glass.  Chemical on wipes shows up as a cloudy film.
