Recently noticed heaters blowing cold on idle. Coolant was low and took over a litre to top up. Checked for leaks around rad area which is suppose to be the most common.
Came across this plate on the block behind the alternator. Appears to be a "cold" leak. Got one from lexus for €10. No seal so some Dirko sealant and good to go. Worth checking out if yours is losing coolant
Interesting, I've never come across that one before.
your gearbox oil looks water free ?
