coolant
asinn
That red coolant you can only get from Toyota... it's really good coolant too. In japan they use red coolant as it can withstand lower tempratures
Either Toyota or Lexus and comes pre made... but not cheap
it doesnt really matter what colour the coolant is - how often do you admire it:lol:
As long as you are mixing the same type ie ethyl glycol and ethyl glycol and not alcohol and ethyl glycol etc etc.
If you look in your users manual then it lists the types and specs of the fluides you should use.
Listen to Rob, he is right!!!!!!!!
