Hi all encountered my first issue. Found oily soot whilst cleaning the engine bay. Would anyone like to advise on what the issue could be. No oil residue on the driveway that I can see. Any way I cleaned the area and ran the car at idle 5 mins to observe. No visiable signs of any leak around that area. Few weeks ago I did see wet ATF pipe seemed like it was oil, may be it was same issue finding it's way down the pipe. I cleaned that area up nothing since Any help be appreciated. Thanks
It's possible to have very slight leaks that aren't always obvious. I had one identified recently in the rocker cover gasket on mine, it was never noticeable on the dipstick and only a tiny little bit of oil was weeping out.
I will monitor it closely. Have you got a Soarer? Does the LS400 share the same 1UZ-FE engine, as wondering were to get gasket set.
I don't think it's anything to be too concerned about but keep an eye on the power steering pump and pipes. And I believe the 4 litre Soarer shared the 1uzfe.
I have an RX not an LS. I got the gasket from the main dealer (2AZ engine).
Could it be rear cam seals if so would a kit be a good idea do the RC gaskets and other seals.
Were abouts in the engine area should I be looking..
I got a bit confused here, you are talking about the 1uzfe engine?
Yes sorry 1UZ-FE wondering were abouts the power steering pump is located in the engine bay. A picture highlighted be helpfully.
These are pictures from another site, they show the areas where the pump can leak, generally a hose, or in my case it was the simple 0 ring that sealed the reservoir to the pump body. Many examples of the pump leaking onto the alternator and wrecking it. Also the steering fluid cooling pipes in front of the radiator can fail. The pump is on the left just above the alternator as you face the engine.
Thanks I will have a good poke around.
Cleaned area as advised. I found bit wet around the area highlighted underneath I'm not losing oil or any noticeable puddles. Should I get the RC cover gasket replaced if so what other seals should be done whilst it's apart.
  • 5 weeks later...
Hi I appreciate if anyone knows the torque spec of the valve cover bolts.
