I’m looking at having my alloy’s refurbished due to them oxidising (which I'm a bit dissapointed about happening already, maybe a new topic for that?). I don’t really want to leave the car just on a jack.
I've no idea of the best position to place an axle stand, front and rear.
So help is needed please?
I would position them under the lower suspension arms, from and rear.
Is there a best position on the lower suspension arm, like nearer to the chassis or close up to the hub end?
14 hours ago, ColinBarber said:
official positions:
83682338_Screenshot2021-03-25at19_05_06.thumb.png.4e22d4f362d541ae6b120c54dbfa80b9.png
This is great and useful to first jack the car up before the need to place the axle stands
I wouldn’t recommend placing axle stands at the jacking points. Not unless the top of the axle stand is flat and fits nicely into the reinforced jacking point. Most axle stands have a v shaped receptacle at the top which could damage the jacking point.
Yes, you need to use the rubber attachments otherwise you are going to put pressure on unreinforced floor/sill or roll over the seam.
