Japsai Chassis Braces Fitted
DaveEllen
Just had my Japsai chassis braces fitted, took an hour.
Car is even stiffer/firm on the road which has further reduced understeer and sharpened turn in.
Car is even lower :duh: so will be raised on saturday.........even scrapes turming into the drive :blush: BTW I raised it 10mm from normal TEIN settings.
Conclusion well chuffed.........will be entering it in the LOC go kart challenge :whistling:
Not particulary heavy maybe 3kg each........
Its the fact that they increase the depth of the body by 15/20mm. My speed bumps are severe (ask dobedo)
Worth rasing the car a tad for the extra stiffness though..........
Have a look at what they replace ! pressed thin steel.
You will enjoy the experience !
if more than one wants the GS ones i will purchase a genuin set, and manufacture my own
Glad you notice the difference with them.......as i said, even on the race car, i noticed a differnce with them fitted, and thats Taut(with roll cage, and front/rear top braces,coilovers and antiroll bars)
Think I've reduced the speed bumps in my road by 2 mm already !
think you may have hit on a new project
"dave ellen speed hump extraction services"
now if we can get mat to make them a bit thicker, you will be able to do 5mm at a time,
:P
