P1120
lexus22
So VSC and ?TRC OFF and engine light all light up, acceleration has gone, plugged in reader and code P1120 comes up, anyone else had this problem?
Strange that the accelerater pedal, seems to not work at all untill it hits a harder push, can actually feel the pedal harder to push, revs and gearbox are all over the place
The fly-by-wire throttle is disabled so all you have is the mechanical throttle cable linked to the throttle body - you need to press the accelerator down almost 3/4 before it starts to work, you only get part throttle range and because the electric motor isn't operating the throttle it is stiffer - it is just a limp mode to get you home.
Yes, think you're right Colin, if the crap weather gts better tomorrow, I will have a tinkers, this is the first thing that has ever gone wrong with the engine. Couldn't believe it!
6 minutes ago, lexus22 said:
Engine is only just about run in😂
Take a look at this video - the sensor get dry solder joints that need to be reworked. You then need to repair the damage you do getting into it - easier just to replace it but may be expensive.
Given that it may be a dry joint issue you may find the problem is intermittent and will work okay the next day but will come back until you correct the issue.
Will endeavor to have a look tomorrow, can't get it in my garage at the moment unfortunately, decided to replace some water hoses on the Esprit, waiting for delivery of parts so can't move it, and other side has the aprilia and lots of Epos stuff that I deal with, got to be done on the driveway, no worries if the weather is good, not big on getting cold and wet🤔😕💦
So weather not to bad this morning, it was exactly as Colin thought, I removed the sensor, desoldered then resoldered the joints, which were all bad and cracking, resealed, put everything back together, reset codes, problem fixed🆒🍺🍺🍺
