PCV VALVE REPLACEMENT/throttle bottle clean on IS250
Guest bigbullhead
Looking at items to service change and a lot of boys with BMW’s change the PCV Valve  on high mileage cars anyone done this? Also throttle body is another that may require a clean?
Hi Mat. Yes there's a few videos on YouTube on how to change the PCV valve. Looks easy but you need a 19mm I think spanner with a 90 degree bend in it. I tried to do mine but the hose to it seemed stuck to it so I've left it for now. As for throttle body I totally recommend it and the MAF sensor too. I posted a thread on it so maybe look it up.
Guest bigbullhead
Cheers for the advice 👍got 145000 on clock so maybe due a clean
Guest bigbullhead
Anybody got a link for purchase I am struggling a bit finding a PCV valve
I changed mine last year.
Your safest bet is to get it from a dealer - the part number for mine was 12204-31040.
I imagine yours would use the same part number.
It was not expensive and you are assured that you are getting the correct part.
Dec.
I got mine from Lexus online shop.
I used CRC Carb cleaner for the throttle body and CRC MAF cleaner both excellent products
I would second Vlad's recommendation for the CRC products. I have found them great to use even if a little difficult to find.
Difficult to find? I found them straight away on eBay and acceptable prices and quick delivery.
I'm in Ireland and some eBay suppliers are not keen on supplying to ROI or if they do the cost of delivery can be excessive.
Guest bigbullhead
Got mine in Japan via eBay as a lot of seller in The US were expensive shipping I payed 23 pounds delivered hopefully no duty
My supplier called Gear Max in Glasgow. I'm not converse with delivery charges to Ireland or anywhere else for that matter but from Glasgow to Ireland I can't believe there are high postage charges. Mine cost under £15.
GearMax's extra charge for delivery to Ireland on one 500ml can is £12.99.  -  delivery is free in the UK
