IS220D 2007 Injector problem - Feed back Volume #4 +5.0 mm3/st - White smoke
Hi
Problem with Injector number #4   - 5.0 mm3/st
1) Swap injector #4 with #3   no change in #4 still 5.0 mme/st   - so cylinder 4 always giving 5.00 mm3/st no matter what injector
2) Put new reconditioned  injector in #4  - no change in the feed back volume
3) In active mode stalled fuel  injector 1,2,3 & 4  no change in injector #4
What is the problem
  Is in the DCU, wiring issue , seal or cylinder valve issue
Have the full readings , i can post
But   - after a while few min  the smoke turns black , and the exhaust leave black soot on ground , temp stable, car judders on acceleration and sometimes gets
Injection malfunction code P1238  but can clear and does not come back for a long period
P1238 doesn't necessarily mean an injector problem. It can be set when a cylinder is operating poorly.
I still think head gasket - common on IS220d.
It may be OK with a compression test but show a problem when running. A sniffer test on the coolant might show combustion gases.
I'm clutching at straws though.
Data readings Idle for IS220D
2008    IS220
2/21/2021 8:19:34 PM
[Engine Stored] System
[Parameter]    [Value]    [Unit]
Vehicle Speed    0    km/h
Engine Speed    792    rpm
Calculate Load     25.4    %
MAF    7.53    gm/sec
Atmosphere Pressure    99    kPa(abs)
MAP    95    kPa
Coolant Temp    55    C
Intake Air    13    C
Intake Air Temp (Turbo)    21    C
Engine Run Time    41    s
Initial Engine Coolant Temp    53.7    C
Initial Intake Air Temp    17.5    C
Battery Voltage     14.1    V
Alternate Duty Ratio    35    %
Accel Position     0.00    %
Accel Sens. No.1 Volt %     15.6    %
Accel Sens. No.2 Volt %     32.1    %
Actual Throttle Position    86    %
Throttle Close Learning Val.     17.3    deg
Diesel Throttle Learn Status    OK
Throttle Sensor Volt %     21.5    %
Throttle Motor DUTY     42.3    %
Injection Volume     9.60    mm3/st
Inj. FB Vol. for Idle     3.68    mm3/st
Inj Vol Feedback Learning     0.9    mm3/st
Idle Signal Output Value    1
Injection Feedback Val #1    -3.5    mm3/st
Injection Feedback Val #2    -1.5    mm3/st
Injection Feedback Val #3    -0.7    mm3/st
Injection Feedback Val #4     5.0    mm3/st
Pilot 1 Injection Period    0    us
Pilot 2 Injection Period    251    us
Main Injection Period    426    us
After Injection Period    0    us
Pilot 1 Injection Timing    -19.2    deg
(CA)
Pilot 2 Injection Timing    -8.3    deg
(CA)
Main Injection Timing    -3.9    deg
(CA)
After Injection Timing     22.3    deg
(CA)
Injector Memory Error    No Error
Target Common Rail Pressure    38960    kPa(abs)
Fuel Press    38530    kPag
Fuel Temperature    34    C
Fuel Route Switching Valve    OFF
Intank Fuel Pump    ON
Target Pump SCV Current     1246.3    mA
AF Lambda B1S1     0.997
AFS Voltage B1S1     0.00    V
AF Sensor Learning Value     1.85    V
Target EGR Position     19.2    %
EGR Lift Sensor Volt %     62.8    %
EGR Close Learn Val.     3.72    V
EGR Close Lrn. Val.     3.72    V
EGR Close Lrn. Status    OK
Target Booster Pressure    93.69    kPa(abs)
VN Turbo Command    73    %
Exhaust Temperature B1S1    76.2    C
Exhaust Temperature B1S2    73.1    C
DPF Differential Pressure    0.300    kPa
Diff. Press. Sensor Corr.    0.2    kPa
Exhaust Fuel Addition FB     1.00
DPF Thermal Deteriorate    Normal
DPF No Activate    Activate
DPF PM Block    No Block
Catalyst Memory Error    No Error
DPNR Status Reju (S)    Standby
DPNR/DPF Status Reju(PM)    Standby
Starter Signal    OFF
Starter Control    OFF
Starter Relay    OFF
ACC Relay    OFF
Neutral Position SW Signal    OFF
Stop Light Switch    OFF
A/C Signal    OFF
# Codes(Include History)    1
MIL ON Run Distance    0    km
Running Time from MIL ON    0    min
Time after DTC Cleared    14    min
Distance from DTC Cleared    0    km
Warmup Cycle Cleared DTC    0
TC and TE1    OFF
Electric Fan Motor    OFF
Data Reading after 40min
2008    IS220
2/14/2021 7:32:11 PM
Engine Speed    949    rpm
Calculate Load     16.0    %
MAF    17.82    gm/sec
Atmosphere Pressure    100    kPa(abs)
MAP    106    kPa
Coolant Temp    80    C
Intake Air    9    C
Intake Air Temp (Turbo)    30    C
Engine Run Time    2444    s
Initial Engine Coolant Temp    80.6    C
Initial Intake Air Temp    26.8    C
Alternate Duty Ratio    33    %
Accel Position     3.90    %
Accel Sens. No.1 Volt %     20.3    %
Accel Sens. No.2 Volt %     36.4    %
Actual Throttle Position    -1    %
Throttle Close Learning Val.     17.2    deg
Throttle Sensor Volt %     69.8    %
Throttle Motor DUTY     58.8    %
Injection Volume     5.95    mm3/st
Inj. FB Vol. for Idle     0.38    mm3/st
Idle Signal Output Value    0
Injection Feedback Val #1    -2.1    mm3/st
Injection Feedback Val #3    -1.1    mm3/st
Injection Feedback Val #4     4.6    mm3/st
Pilot 1 Injection Period    146    us
Pilot 2 Injection Period    161    us
Main Injection Period    125    us
Pilot 1 Injection Timing    -14.0    deg
(CA)
Pilot 2 Injection Timing    -9.9    deg
(CA)
Main Injection Timing    -5.8    deg
(CA)
After Injection Timing     21.4    deg
(CA)
Target Common Rail Pressure    38470    kPa(abs)
Fuel Press    37310    kPag
Fuel Temperature    46    C
Intank Fuel Pump    OFF
Target Pump SCV Current     1261.0    mA
AF Lambda B1S1     0.998
Target EGR Position     0.0    %
EGR Lift Sensor Volt %     75.0    %
EGR Close Learn Val.     3.75    V
EGR Close Lrn. Val.     3.75    V
Target Booster Pressure    95.07    kPa(abs)
Exhaust Temperature B1S1    120.6    C
Exhaust Temperature B1S2    116.8    C
DPF Differential Pressure    -0.579    kPa
Diff. Press. Sensor Corr.    0.3    kPa
DPNR Status Reju (S)    Ready
DPNR/DPF Status Reju(PM)    Ready
Starter Signal    OFF
Starter Control    OFF
Starter Relay    OFF
ACC Relay    OFF
A/C Signal    OFF
# Codes(Include History)    0
Time after DTC Cleared    35    min
TC and TE1    OFF
Tested wiring to 4th injector all ok I removed 4th injector and connected it outside engine to observe pulse and diesel spray looks ok when running ran car hot and forced regen which worked at hot smoke disappears but 4th injector still reads +5 mm3/st next day car back smoking  at idle get white smoke then black with soot on ground
  • 11 months later...
On 3/9/2021 at 9:24 AM, jomjom3535 said:
Injection volume jumping at idle when warm engine shudders then cycles to normal back shudder every min
Hey Jomjom did you ever get to the bottom of this issue with car smoking?
My DPF was removed and 5th injector turned off, car has been driving perfect but started smoking right after refuelling. Now seems like there is fuel issue (loss of ignition or misfire ) when it gets to temperature.
Exhaust smells like melting metal maybe very high temperature. Cheers
