Does anyone know where I can find replacement seat belts (front passenger and front driver) as mine are not looking that good, mould spots etc. on them, they were like that when I purchased the car. Have looked on eBay already and Lexus dealership are asking nearly £500 for a pair! I have tried cleaning them but not very successfully, if someone can suggest what to clean them with, might help?
Thanks in advance,
6 minutes ago, T C Stacey said:
Does anyone know where I can find replacement seat belts (front passenger and front driver) as mine are not looking that good, mould spots etc. on them, they were like that when I purchased the car. Have looked on ebay already and Lexus dealership are asking nearly £500 for a pair! I have tried cleaning them but not very successfully, if someone can suggest what to clean them with, might help?
Thanks in advance,
Ask on here Tony too.                    lexusworld.com
9 minutes ago, T C Stacey said:
Thanks John, but the link you provided no longer works!
Must be the Mods (but I did not provide a link) so perhaps its not them. You can enter the site via your Browser.
Ive put up a long winded post on lexus world on how to clean seat belts, my SC had originally beige interior which i got rid off as its a girly colour 😂 but prior to  fully changing interior trim colour i did clean seat belts which came up near to new condition....then ripped everything out and got black and red interior with red seat belts 😂
Thanks Mr2lad will have a look on Lexus World to find out what you used to clean seat belts. The beige might seem a 'girly' colour, but then it is the wifes car! Mine is a Lexus RX400 Hybrid.
I cleaned mine perfectly with Vanish Liquid & Woolite in a basin of hot water and disconnect the bottom bolt . You can use a clothes peg to stop them retracting back while you are doing it . Soak for a hour or so and then gently scrub with nylon nail brush . Then do it again if needed . finally paper towel dry and remove peg and reconnect the bolt at floor . All this should be avaliable on my post in LW forum " Nicks 2006 Facelift SC"They come up like new .
Basically any fabric cleaner fluid.... i used vanish stain remover in a bucket of warm water with belts unravelled and soaking in bucket... pull belts out as far as possible and but a clip on at top to stop it retracting back, place bucket in rear passenger footwell leave to soak then scrub with nail/scrubbing brush
get Yourself a 1’’ plastic pipe around 6-8’’ long and put a 4’’ cut thru the length of it enough to feed belt thru then grip tight and pull down on it and see the unseen grime oooze out of webbing belt do this numerous times till belt is clean.....worked a treat with mine.... look on YouTube for belt cleaning and you’ll hopefully see what i mean about plastic pipe
Touche .........................😆
Thanks guys, that's really useful advice, I will give that a try!
