GS F owners UK
  • 5 months later...
Imported GSF just dropped onto AT.
Blue, 2016, 38k miles, 1 owner, £34,995
I am very tempted. What should one look out for on a jap import? Will the infotainment be japanese? Perhaps a simple Techstream update ??
mph on speedo, infotainment system, rear fog lights, modifications.
I think you can switch the speedo in the satellite settings, you can in RCF anyway.
Infotainment I reckon someone knows what they're doing on Techstream could sort that out - maybe not. Maybe you need a fresh software installation on the headunit?
Do they not have rear fogs in Japan? Cant see it being road legal here without a rear fog?
Which is why you used to see a lot of imports with a bolt on fog light hanging down off the bumper. The UK has requirements for a rear fog light and there needs to be a separation between brake and fog light - so you couldn't just convert dual brake lights.
Never looked at a JDM GS F - it may be that they use a common rear light cluster on the GS F across the world so everything is good.
Not the sort of thing you can just do in Techstream - if the headunit is the same it will likely need a firmware update.
column stalks are the "wrong way round"
must admit I had started looking at importing a JDM GSF with the current prices of GSF's here.  There was a white one a couple of months ago, 90k miles equivalent, cosmetically needed some work, sold for £12k. then there be shipping and taxes etc......
Jealous of the rear seat controls and heated steering wheel!
I don’t think I’ve seen an imported GSF before. Could this be the first one ?
Looks like it’s missing the carbon interior trim also, which is probably a good thing !
It looks like it doesn’t have the rear fog light in the rear cluster. Maybe you could just swap the inner section of the rear light for a UK one
Possibly, but suspect loom wont have feed for fog light, neither will the stork inside the car have a switch.
Anyway, whilst good chat, all reasons not to bother seen as I already have an RCF...
According to ad, it has mot - presumably fog light is sorted/not an issue then?
I would check out insurance costs - being an import will bump it up (possibly considerably).
