Hi all,
New here and new to the lexus gang. Bought an IS300h recently and its beautiful- absolutely love it. Only thing is barely any of my interior lights on the centre console work! The actual panels work i.e. air con, stereo etc but as soon as the car detects its night time and headlights switch on- the mini AC screen goes black and nothing inside lights up. When I say nothing inside I mean specifically:
1. Clock has no backlight so impossible to read at night but the clock works in telling time
2. The AC panel (with the hazard button) function fine but again, no blue illumination behind it. When the day lights are on the small climate control screen turns on but when its night, it goes black?!
3. The cd player doesnt illuminate either
The window buttons are illuminated and even the USB ports inside the elbow rest illuminate but the main centre console doesnt?! Got a mechanic to check all fuses- everything's fine. Double checked the issue by covering the Any ideas what this could be? I'd rather avoid going to lexus for the £192 fault finding cost.
TIA
If a mechanic has checked it, this may be a silly suggestion but is the panel light dimmer control turned right down?
It's not a silly suggestion at all William. Sometimes it's the simplest, most basic of things that throw us - having an interest in things sometimes makes us start off looking too deeply for explanations.
Yes, you've reminded me that the most frequent fault logged by the computer support team at a firm where I once worked was " N.P.I. ".
(Not Plugged In.)
  • Haha 3
Not silly at all mate. I checked this and it only changes the light settings on the speedometer panel behind the steering wheel (not sure the actual name)
is there a feature called night mode on the IS
so when it goes dark  the un necessary lights are turn off
(Not Plugged In.)
My favourite was telling people it was an I.D. 10 T problem.  I'd usually disappeared by the time they wrote down ID10T 🙂
  • Haha 2
Now that it's getting dark I've tried the dimmer control on my car. There are two settings for the dimmer - one when it's daylight and one when it's dark and the headlights are on. The manual says there are two settings depending on whether the tail lights are on or not but I'm not sure that's correct as I can't get to the second setting until the car senses it's dark outside.
When it's dark and I turn on the lights, the instrument panel lights dim to the level that's been preset. I can control this up and down and although the lights on the aircon and the clock go quite dim they don't go out completely. I know this doesn't help solve your problem but at least this is what I imagine is supposed to happen. It'll be interesting to hear if you find out what the problem is.
Never heard of this... But I tried it last night... and...nothing. Same problem. Complete darkness inside except for when I have a fan on. When a fan is on the light for it turns on but the backlight still isnt on.
(Not Plugged In.)
Squirrelled for future use!
On 1/17/2021 at 1:28 PM, syntax_brandman said:
Hi all,
TIA
Can you confirm that all of the lights in the attachment are working?
Hi Mike, all of those work fine. Its just the centre console stuff- climate, stereo, clock- theres no blue ambience lighting so its super dark
Were you there when the mechanic checked the fuses?  Did he check the fuses in the footwell as well as under the bonnet?
  • 11 months later...
  • 6 months later...
Did you find the source of this problem as my car does the exact same thing.
  • 4 months later...
Hi, have you dectected the source of the problem?
