I have recently when cold had a higher than normal idle and taking a while to get down to normal 650 rpm. But today having warmed up the car first to clear frost after a couple of miles driving the revs dropped low and when stopping at a junction dropped to 200rpm and then stalled it happened again at some traffic lights. I then parked up and did some shopping and when starting up again it was revving about 1200rpm but didn't drop back down for a few miles (the engine was at normal operating temp) also having what feels like an extra gear change between 40 and 50 mph although this has been happening for quite a while when cold. When I got home the revs settled back to about normal having travelled 4 miles from the shops. Brake pad warning light coming on recently when I brake although pads looked good a month ago having only done about 15,000 miles on them. When car dropped to very low revs brakes felt strange a couple of times almost like traction control kicking in only the car doesn't have it being an early '97. Temperature sensor came to mind and possible vacuum problem also. Any input would be gratefully received.
As per Razor61 port, pretty certain this is ECU problem.  I had it on my Mk3, once it started happening the deterioration was quite rapid.  I never got around to sorting out ECU as gave car to a mate for parts to use on his.
There are a couple of places that will install new capacitors if you can get the ECU out, but this was very common problem with cerain capacitors of that era (not just in ECUs).
I thought I had some notes on where in UK you could get this done, but seem to have lost my notes on computer
But this link may be useful How to check ECU
Thanks Pete. I have ordered a coolant temperature sensor and I will take it from there. Has anyone got a set of the caps for the ECU? I was going to have the ECU done the year before last as I was near Devon (think this was one place to get it done) but I never got around to ordering the parts! Any other suggestions on where to get the ECU done will be gratefully received.
4 hours ago, shanra said:
Is it still these 6 Capacitors to replace?
Qty. 2 of 10uF - 50v
Qty. 1 of 47uF - 63v
Qty. 2 of 100uF - 10v
Qty. 1 of 220uF - 16v
According to the post below that is correct but they need to be the correct make and type, there are a few different ECU's which are interchangeable for the MK3 10.1994 - 07.1997 and just one ECU for the MkIV  07.1997 - 08.2000. This is according to website:   Lexus parts catalog (epc-data.com) I presume your car is a MK3? If it is a MK3 then, being a 97 car, the ECU is probably part number 89661-50351 which is the latest version of ECU for Europe (also see the post below about ECU Combability)
I purchased the capacitors from DigiKey in the USA but there is a UK website as well:   DigiKey Electronics United Kingdom | Free Delivery On Orders Over £33
I have an earlier ECU revision for sale on here in the 'Buy and Sell' section along with 5 x sets of capacitors, ECU isn't any use to you but the caps are the same. PM me if interested.
Just one other point, if your ECU is a 89661-50351 then maybe find a second hand unit in decent condition, have the caps replaced then swop it out.
Info for capacitors with correct make and type.
All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor) - ClubLexus - Lexus Forum Discussion
ECU compatibility, this was applicable to the 1995 Mk3 I had.
Thanks Steve I did the throttle body cleaning about 10,000 miles ago. I am purchasing the caps and they will be with me soon and now I need some recommendations for where to get them done. Was there a recall in this country?
Out of curiosity I rang Lexus Parts Direct to establish the build date of my 1996 model, which apparently was built in April 1995. It was helpful because these are the options on Amayama's website, and it saves dismantling to investigate. For example, my ECU, which was only used for 8 months, is 50251, substituted by 50252, but not 50351. Hopefully this helps.
No PNC#
(SUB)
OEM part number Required
per car
Production period Name Applicability Please order in advance
01 89661 89661-50250 01 10.1994 - 01.1995 COMPUTER, ENGINE CONTROL UCF20..EUR 2,163.08 USD
  (SUBS) 89661-50251 01   2,163.08 USD
02 89661 89661-50270 01 10.1994 - 02.1995 COMPUTER, ENGINE CONTROL UCF20..RHD..EUR
SOUTH AFRICA SPEC
2,174.96 USD
  (SUBS) 89661-50271 01   2,163.08 USD
03 89661 89661-50251 01 01.1995 - 08.1995 COMPUTER, ENGINE CONTROL UCF20..EUR 2,163.08 USD
  (SUBS) 89661-50252 01
04 89661 89661-50271 01 02.1995 - 08.1996 COMPUTER, ENGINE CONTROL UCF20..RHD..EUR
SOUTH AFRICA SPEC
2,163.08 USD
  (SUBS) 89661-50410 01
05 89661 89661-50310 01 08.1995 - 08.1996 COMPUTER, ENGINE CONTROL UCF20..EUR 1,782.76 USD
  (SUBS) 89661-50351 01   2,139.31 USD
06 89661 89661-50350 01 08.1996 - 11.1996 COMPUTER, ENGINE CONTROL UCF20..EUR
07 89661 89661-50400 01 08.1996 - 11.1996 COMPUTER, ENGINE CONTROL UCF20..RHD..EUR
SOUTH AFRICA SPEC
  (SUBS) 89661-50401 01
08 89661 89661-50351 01 11.1996 - 07.1997 COMPUTER, ENGINE CONTROL UCF20..EUR 2,139.31 USD
09 89661 89661-50401 01 11.1996 - 07.1997
UCF20..RHD..EUR
SOUTH AFRICA SPEC
36 minutes ago, shanra said:
Does anyone have Chemi-Con capacitors 1 x 47μF - 63v and 2x 15μF - 35v ? It would save sending to America for them.
Panasonic FR are more than good enough - high temp, high endurance, low ESR.
47μF - 63v - 13p from RS, problem is you need to purchase 200 of them 😞
https://uk.rs-online.com/web/p/aluminium-capacitors/9232827/
Farnell will sell you one, but is going to cost you over three times that of RS, at 41p. They have over 15,000 of them in stock!
https://uk.farnell.com/panasonic/eeufr1j470/cap-47-f-63v-20/dp/2760347
Thanks so much Steve let me know the cost and where to send. I will have the other six which I can send with the ECU. It's just the three I am missing.Thanks again.
Got the temperature sensor today so decided to fit it, going along nicely when I realise one of of the screws on the ignition coil is burred try moving it but no go, sit back look at it and see it held on by a frame with two bolts so remove that and then the temp sensor put the new one on hurredly and doing it up and think that it should be tight enough but I pop home and get a Torque wrench (one I've had for ages) set it to 14lb ft and proceed to tighten and tighten, I am now thinking this has to be tight enough and should have stopped but instead of popping home again to get a smaller more expensive and accurate Torque wrench  (which I couldn't find earlier) I press on and then you know what happens I of course break the bloody sensor! So refit the old one and thats another £70 down the pan. No fool like an old fool. Had I been watching anyone else doing the same thing I would have told them to stop  and revaluate. I am trying to blame the Torque wrench for it's inaccuracy but I know deep down who's to blame, it must be those leprechauns I saw on the way to work!!
I hate it when I do not listen to my brain telling me to stop. Plenty of expensive mistakes made over the years.
Well I have fitted the next new coolant sensor and tested the old one and it passed (maybe I should have done this already) and that's one more part that probably won't fail for the life of the luxury palace on wheels!
I think you did the right thing replacing it, the sensor works with very small increments (millivolts I think) so it wouldn't take much to give the wrong reading to the ecu. To quote a post from another forum - "Coolant Temperature Sensor is the "MAIN SENSOR" for the computer. This sensor has more control over the computer than any other sensor". Testing to see if the voltage changes according to temperature on the sensor and testing that it's not open circuit  is one thing but whether it's actually accurate is another thing. It was the accuracy aspect that prompted me to change mine.
