N/S door mirror Folding fault
Alan E
Hi Guys. I am new here and late last year purchased a 55 reg SC430. During my short ownership its has developed a few problems. One of which is frustrating. It's the N/S door mirror, it folds inwards ok, but will not go back to the driving position like the Drivers mirror does. I have to manually move it outwards and when there it is fine.
All  the other adjustments like up/down work great, as does the in/out adjustments. Its just the folding part which is playing up 90% of the time ( it does work 10% of the time)
Does anyone know if if this user fixable or is it beyond our skill level to correct? I am much obliged for any help or suggestions that could help me. Thanks
Hi. I had a similar problem with my SC which had been unused for a while before I bought it last summer. A liberal dosing of WD 40 between mirror and its bracket did the trick. Good luck - and enjoy
Hi Andrew. Thanks for your help. I sprayed the mirror housing (Blindly) with WD40 and left for a few days to do it's thing. Tried it yesterday and low and behold Magic it worked as sweet as a nut. Perfect, Thanks very much for helping me sort this out
Alan, Not Magic, but a Miracle. Hallelujah!🤣
You are right there John. I am still in disbelieve I got it rectified so easy.
On 1/16/2021 at 5:27 PM, markeyszoo said:
I came out 3 days ago and neither mirror would open up. They were frozen solid. Took a couple of miles for them to defrost.
Makes me happy that I live where temperature is 15 degrees Celsius at night and all local born tell me it is freesing cold.
Did you actually drive a couple of miles without mirrors?
the mirror on the front windscreen was working.
Remember that i come from a generation when the outside mirrors were located on the front of the cars wings and useless.
"the outside mirrors were located on the front of the cars wings and useless".
and
the wipers were vacuum operated
the indicators were semaphore
the windscreen opened outwards
the drivers door was hinged at the B pillar
the plugs could be changed in  a short while
a de-coke was performed every 10,000 miles and,and,and
Edited by royoftherovers
typo
and
You sound the same age as me John, dad had a 1946 Hillman Minx it had semaphores and a opening windscreen and doors hinged on the B pillar, didn't do a de-coke but remember buying pads and a bag of copper rivets and fixing them to the old brake shoes.
And did we both sleep with Anita Ekberg and have a peek at Dad`s copy of Reveille,  David?
Jane Asher for me John, Macca was mad letting her slip away, dad must have kept his mags well hidden.
Not wishing to upset you old pal, but I think I slept with Jane Asher before you did. A really lovely girl.
 As was Marianne Faithfull before she slid down a hole.
You b******d I knew there was something going on.
  • Haha 2
and
Wing mirrors on Toyota Camry
related but not the same ................if you have a problem with your door mirrors not going up /down /left right. There are 2 motors in the unit that can be replaced / repaired . The IS mirrors have the same motors and are more common to buy on eBay
PS I thought I was the only one they slept with ........
