Posted (edited)
Dear All
I own a Lexus IS250, my Battery charging wire got in the way and broke the Plastic hook for the boot. Unable to close boot at present as electronics drains Battery. The Lady Needs help to move around Covid restrictions. Based in south London. Contact 07711543433. The Pictures show are the plastics that bounces the wires the third picture is a sample  for eBay Australia is the position in the boot which this plastic slots.
Photos.app.zip
Photos.app.zip
Edited by Elaine Hope
Needed to add more pictures to illustrate
Guest bigbullhead
Man in oz does 3D printing I require one too so we could order at the same time and share postage
I'm a bit confused. So the plastic piece is broken and the boot won't lock? Why am I confused? Because I noticed mine has broke in two. Left hand side still goes down when pushed but the boot locks. Surely there must be another reason why your boot won't lock.
Oh and as for those photos app zips. I clicked on the first one and all hell broke loose. Over 2000 items downloaded in a couple of seconds. What gives?
Yes I agree, I always assumed that piece of plastic was just cosmetic to hide the boot latch.
The boot on our IS250 failed to close shortly after it was repaired after being rear ended. It required a whole new locking mechanism, which was sourced and fitted  by Lexus Bristol with in 24hrs.
I think the OPs problem it’s most likely something to do with the locking mechanism in the boot lid than that piece of plastic.
Guest bigbullhead
Unless something is catching and stopping it locking
Guest bigbullhead
I think you have to buy the whole bit across the whole bit of boot?
Might be that the metal bar that acts as the hinge is jamming lock mech.This guy had a redneck fix.
Blimey that was a good video. Amazing how much crud builds up in that drain channel. That's a job on the to do list. 👍
