Can anyone please help I'm totally stuck ,I have not driven my 56 plate is 220d for a week and now it is not responding to either of my fobs , I put a new Battery in my main fob but still no joy. I can open the door with the mechanical key but the alarm is activated , then I can hold the fob near the start button and start the car but the alarm continues. Obviously I can't drive it with the alarm blaring.
Has anyone any idea what's going on with it ? I would really appreciate any help.
2 minutes ago, Treebor60 said:
Can anyone please help I'm totally stuck ,I have not driven my 56 plate is 220d for a week and now it is not responding to either of my fobs , I put a new battery in my main fob but still no joy. I can open the door with the mechanical key but the alarm is activated , then I can hold the fob near the start button and start the car but the alarm continues. Obviously I can't drive it with the alarm blaring.
What is the condition of your Battery?  A week is long enough to leave a car if the 12v Battery is weak. It can also affect the alarm.
I'm not sure how good the Battery is but I assumed it would be ok as it is starting the car , but now you mention it for the last month or so I have thought it was struggling to start it.
Do you think that could be the problem ?
2 hours ago, Treebor60 said:
I'm not sure how good the battery is but I assumed it would be ok as it is starting the car , but now you mention it for the last month or so I have thought it was struggling to start it.
I would nip into a place that sells batteries and tyres etc and ask them to do a quick Battery test.  Sometimes disconnecting the Battery earth for 10 mins can reset everything but if it's duff you'll need a new one asap.
Looks like my Battery has had it , when I install a new one I presume I will have the alarm blaring , will it stop once a new one is connected  ?
Thanks for all your replies
43 minutes ago, Treebor60 said:
Looks like my battery has had it , when I install a new one I presume I will have the alarm blaring , will it stop once a new one is connected  ?
Just have your key fob to hand and deactivate the alarm if necessary
There's some good advice on which Battery to fit if you search the forum. I suggest Yuasa
I suggest Bosch S4 026, which can be got for about £75 right now!
Thanks for the help but as in my original post it's not responding to the fobs and when I open the drivers door with the mechanical key the alarm goes off,  and I'll have to do thatvtonopen the bonnet
