Hi y’all
I’m new on here so go easy on me. ☺️
I’ve recently purchased a GS300h 2015. Excellent car.
Quick question:
With which option can the large video screen display the USB video in full screen?
(I’ve tried and am only getting an ‘expand’ option which does not give me a full screen.)
Thanks in advance.
Uhm, probably the point is that video is 16:9 ratio, so if you also set the screen for single vision, the height of screen does not change 🙂
Expand option only cuts upper and lower  of video image so that you can see a bigger image losing slices of original source.
Thank you, Zotto.
I have tried this and the video is still shown in only part of the screen and not full screen.
Maybe the fullscreen option is only for 8 inch screens?
12" screen is for double data display, and usually I let it divided left side with map and right side with radio or energy monitor, bur I tried sometimes single display on all size screen, with maps,  and it works.
Thanks.
I’m going to play around with it and see what it allows me to do.
How did you do this? I can only get navigation on the left hand screen. Mine is a 2014 my.
I the vertical line  where you select the secondary screen (radio, engine data etc.) there is a ">" sign , click there and screen becomes single.
I don't have that on mine. All I can do is put the right hand screen to the left. Cannot expand the map screen. Maybe yours is an updated version.
It should be possible to have a single display on screen. Try giving a  look on configuration menu.
I don’t have the option, unfortunately. I’ve checked everything I could. (2015 version)
