Is there a way to swap 2006 -2010 lights to the 2011 to 2013 oem headlights?
For the drl feature?
Is it a straight swap? My car is 2011 and I have AFS enabled headlights.
If so. Where can I buy them from?
I may be wrong but even if they were a physical fit and straight swap, you'll probably find that there is no wiring or relays for DRLs in your car so you'd have to sort that as well.
I'll have to look into this
Yes 100% possible. I did it back in 2013 and still going strong. Check out my blog post: https://is-250.blogspot.com/2013/08/2012-oem-led-headlights-installation.html
9 minutes ago, Marleez said:
Nice. Is it possible to get the 2011 to 2013 oem lights with afs?
No, LED DRL headlights lost the AFS functionality to make room for the drl
I see. I dont need afs. So I'll have to find a pair of lights
First pic when it was wrapped in white from 2014. The other pics are recent photos with new paint colour
