Hi All,
My car (Gen 4 RX450h) is in at Lexus at the moment to fix the seat memory setting which doesn't work any more. Seats adjust fine on the seat controls and everything else seem to work. This came about after the drivers door mirror refused to fold or adjust. This has been fixed under warranty, but they seem to be scratching their heads over what is causing the seat memory problem and they've had it two days so far. Has anyone else experienced this and if so what was the fix?
Any assistance much appreciated.
Graham
Try resetting.
Move car seat to max rear setting. Then max forward.
Then max recline and finally max tilt forward.
This worked for me after Battery disconnect lost my memory function. (GS450h)
Thanks,
Lexus have apparently tried this but no joy.
