It's available on the Lexus website to view as a PDF document. Most fluids get changed including coolant, rear diff. Not sure if transmission oil is changed, dependent on the inspection I believe. Why not ask the service center for a full breakdown via email.
I’m still waiting to get my 100k service done, at 26 years old it’s only on 93k now 😀
I was thinking about having mine done at Lexus but the quote including sparks for an IS was £705. That is quite a bit, but I did understand most of the fluids got changed and the sparks are supposed to be a bit fiddly. Whilst is no doubt a thorough check over the car, the price is too high for me. Going to go for a local specialist when the time comes instead and save a few quid.
Good move. Find a competent garage who are happy to do the work and fit owner-supplied parts (many will refuse to do this) and you should be able to save a considerable amount.
I did this recently for my 60K (spark plug) service and even using genuine Lexus parts & oil, saved about £250.
It's nice to have a Lexus stamp in the book, but the car is old enough now that it's not worth that kind of additional expense.
Sent from my SM-G986B using Tapatalk
