HI guys been having bit of trouble with my gearbox
making a noise when OFF the clutch when on it goes away
its had new input shaft bearing and clutch release bearing clutch plate and pressure plate
all put back together and its still fuc$%^g doing it
any ideas
thankyou
What sort of noise? When it is is in neutral and the engine idling?
Was the flywheel checked over when the clutch was looked at? The dual-mass flywheel can develop a noise.
it does sound like it revving with the car
yes thats right when its just sitting there idling out of gear parked up
Top of the suspect list would be the DMF usually worn or broken springs, not sure if you can replace with a solid one.
I’m no expert on DMFs and obviously not looking at your car it’s just an opinion of the possible cause.
Have a read at the links from this google search.
“Symptoms of a worn dual mass flywheel”
yea i will do i think its kinda making sense as i took the gearbox to a local specialist and he said hes happy with it and they are very reliable and its got new bearings in there and brand new 3 piece clutch
