Hi, Can restaurant poi be deleted from the sat nav display on a 2016 NX300H uk version..I’ve looked and tried but to no avail...
Thanks...
You should find in nav menù all poi's and delete the option for restaurants.
You don't have to tell us if you don't want to Noddy but I'm sure I can't be the only one sat at home wondering why the restaurant POI has offended you so much that you need to remove it - can you not just ignore it? :whistling:
Does he want to delete the subject of Restaurants or does he want to delete a particular Restaurant from within the subject?
A POI file (as I understand it) isn't just a list of things that can be edited, but rather more of an 'app' or computer program that is compiled into a self-contained 'package' that can't be edited. I stand to be corrected if I'm wrong though.
Reading my Nav handbook, if one follows the menu options bellow one can select to display all or no POIs and also which POIs categories are displayed
Display the map setting screen:
 “MENU” button  “Setup” 
“Navigation”  “Map”
2 Select “POIs on map”.
3 Select the desired POI categories.
Seems straight forward if he wishes to delete the Category.
Points for use of Handbook are currently unavailable !
Just to mention, one doesn't actually delete anything, simple options not to display the POI icon on the map
The problem is when in an area with many restaurants the restaurant POI‘s blots out the roads therefore making the display useless...
Doh! Didn’t realise there are two different screens for displaying POI set up, one in set up the other in map, now sorted..Thank you all...
Drinks all round!
Noddy will pay and select the Restaurant!
