Buzzing/Rattling sound from ventilation.
Hi Guys
I have a Lexus IS 200D 2,2 from 2010, 212.000 km. There is some rattling noise from the ventilation. I removed the radio to see if there is anything loose, but I can't find anything. I've recorded some videos and uploaded them to YouTube. Hope somebody can help me. This is so annoying :-)
https://www.youtube.com/watch?v=dM7c993Yb70
https://www.youtube.com/watch?v=Ou7soNWM6Oo
https://www.youtube.com/watch?v=vT674KiYz_Y
Thanks in advance
Sincerely,
Elvedin T
I can't  really make much out from those very short vids ( apart from the derv doing what it does best!)
And +1 on above re cabin filter but remember to only ‘play’ with it in ‘’Recirculating” mode or you may break the door/servo linkage.
Check out the thread below, and I have actually got that piece of rubber/foam in my car right now which must have been fitted by a dealer prior to my ownership.
Hi guys
Thanks for the replies. The problem is it only happens at 2000 rpm. It comes slightly and the stops when I pass 2000 rpm.
I will try to put up another video. I tried the pollen filter.
I attached a picture do describe where the sounds come from or I believe comes from. When I put a hand on that area it vibrates when the rattling sounds come on.
The picture shows the white ventilation box.
BR
Elvedin
