Is 250 2010 Exterior Door Handle
Hi guys, this forum has been very insightful, thanks everyone for your contributions. I parked my Lexus Is 250 2010 at Asda  and went shopping and noticed someone tried to steal the car. He made a big hole under the exterior door handle of the passenger's side. I called Lexus and the quoted £412 for the door handle and fitting which is quite expensive. Please any suggestion where I could order it and fix it? Thanks.
Hi Vivian. Sorry to learn of your plight. Can you take a photo of where the hole is? Unbeknown to many owners there is a small key size slit on the underside of the handle. This is so that you put your key in thst slot to prise it off revealing a normal looking key hole so you can get into your car if the remote fails.
