Fuel pump popped a pipe of the top,,replaced fuel pump,,fuel pump back working
Engine cranks,,has spark and fuel but no voltage to the crank shalf senor
Checked all fuses and replys all good
Any idea people 🤔
if your crankshaft sensor isn't working then the ECU won't send a signal for the ignitors to generate a spark. It needs to see a crank signal when cranking the engine before it starts ignition.
Thing is i have spark,,aim getting voltage for a second to the crank senor,,and then it stops 🤔
Like the ecu or something is telling the engine not to fire
When it cranks do the revs register on the rev counter?
If there is no movement on the rev counter I would be inclined to suspect the crank sensor.
