hi all
I went to push my headlight jetwash button and it has popped out of its surround thus leaving it unusable.
Any ideas to how I can attach something strong to it, so I can pull it back into its surround casing.
Hope  this makes sense .
This should help if I'm right in thinking that the switch in question is on the trim containing the seat heater switches and the cig lighter.
Its going to tricky....think I might put a blob of silicon on the button and bed into it something like raw plug or plastic tube and let it set and see if i can pull it into position....
Thank you Herbie for sharing this video
It's really a very simple job. Five minutes and you'll have the trims off, switch back in place and trims back, job done.
I took mine out to change the cig lighter for a USB socket for my phone and anything else that may need a USB connection:
That's a great idea herbie ....do the electrics need to be soldered or is it an male female type connection
Well, it's more than 3 years since we traded the RX300 in so I may be wrong, but I'm almost certain that they were just normal push-on spade connectors.
I will see whats what when I attempt to pop the wash button back in ....will attempt it tomorrow ...will let you know how i get on
