Button on NX roof
Check the owners manual to be sure but it's usually something like this:
1) Press the lock button on your keyfob, motion sensor is activated (test this by being in the car when you do this and moving your arms around, alarm should go off)
2) Do the same and press the button, motion sensor should be deactivated (test by waving around in the car while locked, alarm should not sound)
3) After locking with the fob, press the lock button a second time. The hazards will flash again to indicate the motion sensor has been disabled. Again you can test this by being in the car when you do it.
Note: this is how it has worked on previous cars I've owned, my current car doesn't have a motion sensor and yours may be different. Check the owner's manual for confirmation or test as suggested.
