Throttle Body Cleaning Question
Last time I had the throttle body cleaned was about 35,000 miles ago.
Only drive the car about every ten days at the moment, but get low idle revs (about 400rpm with a bit of hunting up and down) from time to time, wondering if the throttle just needs another clean, any thoughts.
Pretty certain its not a ECU capacitor problem, as had that on previous LS, and that was low-idle/stalling after long runs.
Yep, the earlier models up to October 1994 used a Karman Vortex AFM which uses optical measurement of air flow and cannot be cleaned. The later models use the Hot Wire AFM which can be cleaned with care.
