If your car has just passed it's MOT ( with some 'Advisory' notes attached) then you don't need it MOT'ed again til next year and if the 'Advisory' items get addressed with the warranty work then they won't be a problem next year.
As @royoftherovers says check the warranty documentation, but even if it would normally be excluded I think you could make a case that it’s only necessary because of the other stuff so I’d push for it.
Back home now after picking up the car.
They said they will contact me once the parts have arrived as it will need to be imported in due to lack of stock in the UK.
Thank you all for the support
  • Like 4
Do you know what exactly was the suspension issue?
Rear springs / shock absorbers or front suspension?
Has anyone else on here with a 450h has suspension issues?
