It "will" fit but the OEM offset for 17's are ET45 and these Borbets ate 40 and they will stick out 5mm more
Hi Andrew,
Thank you for getting back to me, what can I do about that? Would it be very noticeable? Is there anything I can do about it or not really.
Thank you 😄
Haven't played with aftermarket wheels for a long time. 5mm may seem small but it could rub or might not! it will sit flusher to your arches
Have to suck it and see i'm afraid
Hi Andrew,
Thank you - I will probably look at something with an offset of 45 instead as don't want to take the risk. Thanks for your help.
