I noticed a few days ago that my front driver side door was rattling a bit at certain speeds above 40mph, just enough to be annoying, with nothing in the door pocket. Sounded like possibly a loose screw. Today I pulled the door card off and found it was indeed rattling when shaken, it took quite a bit of shaking at different angles but eventually a total of four 5p bits fell out.
You live and learn, don't put coins in the door pockets!
Coins could also have slipped out of trouser pocket.  I have found this had happened in a car before now and also down the sides of my normal armchair.  Anyway, good you found cause.  Rattles can be irritating.
I’m a bit OCD with rattles. I had a beemer once that drove me nuts for weeks because it started squeaking from the nearside dash. Eventually tracked it down to a piece of polystyrene inside the A-pillar trim.
