Factory alignment specs GS430 MK2
Delp
Anyone got the factory alignment specs for GS430 MK2. Be much appreciated. As going for another alignment but this time I be making sure that they competent and do a good job as long I know there going by the factory specs.
My front camber bolt was seized up when this alignment was done. Know the bolts are freed up I'm going to different place tomorrow so hopefully they get it right. I know nothing about alignments. I suppose you got to trust the person doing it. What is SAI and thrust angl
Got the alignment done on recommendations. It does drive better than before. Still steering sitting to left slightly. Any input on the adjustments made..
