I think while there's still demand there will still be supply, you should be fine for a good while yet.
You could use the premium grades, such as V-Power and Momentum which will remain E5
E10 is available in Germany for a few yers. It doesn't mean E5 is gone, it is just another option. Here is a typical choice you got:
Super 95 E10 is normally few cents cheaper than standard Super 95 (E5) - choice is yours.
Any issues with the higher ethanol fuel having a lower specific energy than "pure oil"? Higher fuel consumption possibly?
2 minutes ago, Greer said:
You could get an LPG conversion and keep the car for as long as you want, LPG is about half the price of petrol
I probably don't do the mileage to make it necessary to be honest, probably 4k/year or so now.
I posted on this last month, and have included the advice below which may help.
The following advice applies to Lexus vehicles-
E10 petrol is cleared for use in all Lexus European petrol models made from January 1998, excluding:
IS250 2.5 litre V6 with engine 4GR-FSE made between August 2005 and September 2007
GS300 3.0 litre V6 with engine 3GR-FSE made between January 2005 and September 2007
LS460 4.6 litre V8 with engine 1UR-FSE made between August 2006 and September 2007.
https://www.moss-europe.co.uk/moss-blog-e10-petrol
15 hours ago, TyrannosauRoss Lex said:
Thanks for that, seems very expensive, may as well just get the super unleaded.
It is, but when the government mandate that all petrol must be E10, including Super, then at least you can keep running the car, if you still have it.
Most pre-unleaded cars are having to run additives but they do tend to be low mileage.
I'm curious if there is any country in the world where E10 is the only available option.
