I folks, has anyone hard wired a dash cam to a 18 reg RX450h?.
Thanks John, I should have done a search, sorry.
Fitted a front and rear one into mine, tucked all the cables under the trim and wired it up to a live feed in the fuse box under the glove box. First had it in my IS, transferred it to my NX and then onto my RX.
Thanks for the reply Colin, I'm going to give it a go, but just a front one for now.
You might want to fit a “powermagic pro” you can set it so it keeps the camera powered when the car is parked and then it monitors the Battery level and switches off at a preset level.
22 hours ago, C Mclean said:
You might want to fit a “powermagic pro” you can set it so it keeps the camera powered when the car is parked and then it monitors the battery level and switches off at a preset level.
Have ordered a Nextbase  422GW and a hard wire kit, thanks for your input Colin.
