Hi all,
Which is the best and cost effective engine oil to get for my CT200h 2011 model ?
K
there is only 1 cost effective engine oil to buy and that is
the correct one i.e. 0w-20 as per lexus recommendation
whatever you do dont scrimp on your engine oil
it will cost you far more than you will ever save in the long run,
i think Shell Helix ultra is the one lexus uses its not cheap here is a link for 1ltr bottle
https://www.opieoils.co.uk/p-92101-shell-helix-ultra-sn-0w-20-pure-plus-fully-synthetic-car-engine-oil.aspx?VariantID=167786&gclid=CjwKCAjw0_T4BRBlEiwAwoEiARLkKAwoH2agCoxuhqAcTV9JosJ7bVHnoF1NpM2hlwdREJJRVGnjOxoC_t8QAvD_BwE
Shell is what my local dealer uses. I never though need to top up between oil changes. In fact, I can't recall having to top up any modern engine between services for many years.
Is your car losing much oil?
Asking the same. It shouldn’t be using any oil between changes.
My 2011 is on 106K and doesn’t lose any.
Small engines and city driving demand a high quality oil.
Some engines are designed to use oil for better fuel economy, one litre every 1000 miles is considered normal. However in the long run this burnt oil goes through the catalysts who get blocked and need replacement, so where is any fuel economy!
I use Amsoil API SN  5W30   ILSAC GF 5 for warm weather. For uk 0W30 is recommended and the oil level never falls even a hair line below the max level irrespective of driving style.
Chris.
On 7/26/2020 at 11:37 PM, 200h said:
i think shell helix ultra is the one lexus uses its not cheap here is a link for 1ltr bottle
It is a common one that dealers use. Obviously Toyota/Lexus recommend Toyota 0-20W for the CT, which I believe is produced by Mobil but to Toyota's specifications.
Chris.
The correct oil for use in the UK is 0w20, and the handbook states if anything else of a higher viscosity is used it should be changed for the correct grade at or before  5000 miles maximum. The correct grade need not be changed till 10,000 miles. It also states using anything other than 0w20 will have a serious impact on fuel consumption.
Prius Chat forum bears out this with reports of people getting a loss of up to 15 mpg by using 0w or 5w30 oil.
John.
Quite right, 0w20 is the correct oil viscocity for uk,  I was writing the post when something interrupted my sequence of thoughts.
I stand corrected.
Chris.
I stand corrected.
Chris.
We have all made mistakes "in my case senior moments" when we write or say something different to what our brains are telling us. I have done this several times on this forum.
John.
I have never topped up engine oil on my Lexus between services, in fact I do check the oil and washer bottle, but my oil is so clean, its just as if it has just been changed, and never needs topping up,
