starting to wonder if the car is a problem.
First time had this problem but afs light flashing  airbag light on    temp gauge not working,  a/c "check connection",  fuel consumption not working.  Switch off and rest for a hour. Starts to work  then all off again!!!!! Disconnected Battery for the night to see if I get a reset.
Probably the Battery on it's way out. If you have a charger I'd put it on charge overnight and see what happens. Modern cars are very unforgiving of low batteries.
If you have a multimeter this chart will help:
